I tried a very simple geometry and get the error you can see in the image. I never noticed this behaviour in the past and have no idea where it comes from. Any idea?
Cotty
Whats going wrong here?
- test.zip
- Testmodel
- (52.48 KiB) Downloaded 153 times
- zeitmeister
Re: Whats going wrong here?
Looks like a depreciated polygon; which you should avoid in any cases.
Did you try various render modes?
Hi, sorry for the late reply!
This is indeed probably caused by degenerate triangles created from polygons with a large number of sides, very long and thin triangles which mess with computations such as normal smoothing.
Try turning off normal smoothing for the flat surfaces (if you're using Blendigo, you'll need to wait for the next release).
Dale solves this (exporter) problem, see this topic: http://www.indigorenderer.com/forum/vie ... 4&start=30
