Download Trial Buy now
Log in or Sign up for the chat.
Search  | Login  | Register
Post new topic Reply to topic  [ 7 posts ]
Offline
Right now alpha is embedded and background is removed. Idea is to add black-and-white alpha mask similar to current depth, id and shadows in render mode.
It would give something like this in cycles:
http://blender.stackexchange.com/questi ... ha-channel
...or in vray:
https://www.vray.com/vray_for_sketchup/ ... tion.shtml
(maybe contribution would be set automatically depending on transparency).
This feature would allow compositing with background visible e.g. for clouds on physical sky, replacing only part of background HDR or adding fog to objects and partially to sky where needed.
_________________
http://www.mastersfinger.com
 Profile
Offline
Hehe, Indigo had this until 3.6 when it was replaced with foreground alpha. That said I think it'll hopefully find its way back in some form.p
_________________
http://fb.me/OscarJDesign
https://www.behance.net/OscarJohansson
 Profile
Offline
So... maybe both options are possible :)
_________________
 Profile
Offline
Agreed. :)
_________________
 Profile
Offline
Hm.. I don't see why you can't just re-composite the sky back in using Foreground Alpha?
The alpha pass gets really tricky once you have glass, fog, other transparent materials, etc. How does your color pass then look to compensate for partially transparent pixels? In my experience the foreground alpha method works much better in these cases.
Also, you can extract the alpha channel from a PNG with transparency, which would give you the BW alpha pass.
_________________
http://www.tomsvilans.com
 Profile
Offline
...exactly my thought, just select the transparency of the png and make a new alpha channel from it
 Profile
Offline
Indeed, you are right, I forgot about that. But to composite aerial perspective you have to render scene without objects, right now no such option in blendigo and doing it manually you can make mistake like files overwrite.
Background re-composite (with rendered pure background) will let you make aerial perspective or clouds perfectly visible through glass (without refraction).
Right now steps involved to get aerial perspective:
- render image with background alpha enabled
- render background (objects turned off)
- render z-depth
- extract alpha mask from main image (for fog-on-objects compositing)
- composite fog on objects and that on background
It seems that to create complete and easy (no extracting) passes solution there should be "alpha-mask" (as in req) and "background pass" and like e.g. in cycles:
http://blender.stackexchange.com/questi ... background
_________________
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
