Liquids Test Thread
Liquids Test Thread
First up:
Milk(reduced) from the Indigo Manual. I rendered this to something like 14,000spp and then i realized that I did not have the proper phase function settings. It was set to Uniform instead of Henyey-Greenstein. However, when I started the render again using HG, the results seemed to be nearly identical, except for more bright blotches that cleared extremely slowly. I abandoned the HG render because I thought the result using Uniform phase function turned about pretty decent.
Feel free to post your own liquid tests, but please make sure the following:
- The scene is modelled real-world scale
- Liquids in glasses are modelled as shown in the Indigo Manual with correct precedence settings
- Please share your material settings
- milk.png (236.17 KiB) Viewed 6016 times
Re: Liquids Test Thread
Coke from the Indigo Manual:
Seems a tad dark to me. Might look better with ice cubes and some fizz bubbles.
All renders tests done with Indigo 2.0.X Bidirectional MLT unless noted otherwise.
- coke.png (221.56 KiB) Viewed 6015 times
Beautiful materials Whaat, but the milk seems to paint white!!!! xDD
I like coke! Thank you
- Borgleader
Nice but, like said above the milk somewhat does look like paint, also the coke is wayyyyy too dark. I drink a ton of it
Also why is the milk faceted where as the coke isnt?
Because he probably realised, after having rendered the milk, that he had forgot to push the "smooth" button
Same remarks as above, the milk looks like paint and the coke is a bit dark. Is your scene scaled correctly ?
I've also been playing with some SSS liquids lately. Wanted to try out the orange juice material Whaat made. I hope you don't mind me posting my tests here too?
The 1st img is Whaat's juice mat. Works very good I think!! Thanks Whaat!
And the 2nd is my try on low fat milk from Indigo's manual. I tweaked the sss values a bit for it.
- orangejuice.jpg (39.73 KiB) Viewed 5857 times
- milk.jpg (44.22 KiB) Viewed 5856 times
- Borgleader
Call me paranoid but I see facets on your too
True. I see them too. I wonder if it could be SSS related thing?Borgleader wrote:Call me paranoid but I see facets on your too
Great juice
And i see the facets to
I was trying to make milk myself one day, but the rainbows from sss made my almost go mad
I am 99% sure my meshes were smoothed. I think it could be a bug with SSS. Liquids with small SSS values are not showing this faceting for me.suvakas wrote:True. I see them too. I wonder if it could be SSS related thing?Borgleader wrote:Call me paranoid but I see facets on your too
- Borgleader
I can't see them on the orange juice so I guess you're right it could be a problem with the SSS behavior.
Another render of my juice material. Not sure why it's blackish around the meniscus. This is apparent on suvakas' render too
- orange_juice_in glass.png (241.26 KiB) Viewed 5781 times
- Borgleader
Tbh i think its normal. At that spot the "juice" is very thin and clearer, and so the black comes from the joining of the clear "water" and the glass kind of like the top of the glass. Or at least I think so.
Not sure my post made sense but,,,
Watered down wine:
These tests compare Merlot wine renders at various concentrations (diluted in water) to the renders in the Jensen paper. Although the renders are similar, it is clear that the Indigo renders seem to absorb more. The Indigo parameters are from the Indigo manual (converted from the Jensen paper). I am quite certain the values in the Indigo manual are correct. I checked them several times. Is it possible that Indigo is not calculating absorption correctly?
- Jensen 25% Merlot
- merlot_ref_0.25.jpg (16.8 KiB) Viewed 5753 times
- Indigo 25% Merlot
- Merlot_0.25.png (300.07 KiB) Viewed 5759 times
- Jensen 12.5% Merlot
- merlot_ref_0.125.jpg (16.96 KiB) Viewed 5742 times
- Indigo 12.5% Merlot
- Merlot_0.125.png (293.1 KiB) Viewed 5753 times
- Jensen 3% Merlot
- merlot_ref_0.03.jpg (16.77 KiB) Viewed 5732 times
- Indigo 3% Merlot
- Merlot_0.03.png (323.47 KiB) Viewed 5739 times
Yeah, there's something incorrect somewhere.
