Shelby Cobra 427
I guess I should go back to that. I made them, then didn't look at them again, but you're right about the squareness.
I have no idea how to make a bump to do what I want to do for a headlight. Any tips would be good
I tried colors becuase I didn't know about the temperature option. Where is it?
Hi doublez !
I can't tell you where temperature setting is because I don't use blender, but first you will have to switch light type from RGB to blackbody type, explore blendigo UI a bit Then when using temperature, the reference one will be set from the camera white point. Any light featuring a temperature below this one will appear reddish, temperatures above will tend toward blue. A light with the same temperature than camera white point will be... white of course !
Now for the bump... I didn't bother with searching for a reference image but I believe that blurred vertical stripes would do. A quick howto would be:
- Make a new image in your favourite painting software, say 512x512.
- make your way to have alternatively B&W vertical stripes, say each 20px wide (20px white, 20px black and so on).
- blur the map until all edges appear soft and you are set, basically.
On more recent vehicules the design would be different of course but that one should be good enough for a starting point, and for this Cobra thing
I hope that helped !
- Borgleader
Hey yes !
Well it's true that with RGB you have more saturation, at the end you do what you want doublez (no need to be a "master" as I stated ) None the less I'm glad I helped you in aknowledging the temperature stuff !
I guess the bump u used for the windshield can do well for headlights, just waiting to see the result.
I like what I got with the blackbodies and it was really easy to get. I don't know if I could get the same with rgb.
The bump is on the headlight too, it's just scaled to small. The windshield and the headlight had the same material assigned so the bump was put on both pieces.
What should I do about the vent on the side? It has a chrome material and it's reflecting the emitter, so it's white. Should I just use a different material, something less reflective? Maybe plastic?
- Borgleader
Users browsing this forum: Ahrefs [Bot] and 53 guests
