by neo0. » Thu Jun 26, 2008 8:29 am
I set the precedence glass>fluid>tube, but I can't seem to get the outer glass to show up. Its supposed to be green, but its just transparent.
- render time 30 mins
- im1214424562.png (1.49 MiB) Viewed 3530 times
by PureSpider » Thu Jun 26, 2008 8:52 am
Is the outer glass a volume or just a plane without thickness?
by neo0. » Thu Jun 26, 2008 9:17 am
The outer glass is a volume, yeah.
by PureSpider » Thu Jun 26, 2008 9:31 am
Then it's probably too thin
zsouthboy
by zsouthboy » Thu Jun 26, 2008 10:54 am
Precedence should be glass > tube > fluid.
by neo0. » Thu Jun 26, 2008 11:09 am
Thanks, now the fluid refracts the tube.
Is there a rule for this?
by CTZn » Thu Jun 26, 2008 11:44 pm
I guess it's: outer shapes = lower precedence
by PureSpider » Fri Jun 27, 2008 12:20 am
No lol higher!
handsomedave
by handsomedave » Fri Jun 27, 2008 2:06 am
Higher precedence volumes displace lower precedence volumes is an accurate way to describe it I believe.
by Kram1032 » Fri Jun 27, 2008 2:34 am
yeah, kinda...
Which one should be higher really depends on how you modelled it
by neo0. » Fri Jun 27, 2008 7:23 am
Progress
- sds
- im1214434588.png (1.25 MiB) Viewed 3228 times
by Kram1032 » Fri Jun 27, 2008 7:28 am
two things about the floor:
a) it's too flat
and
b) that lighter has to be extremely huge according to the brick-size
Try to find a higher resolution floor in order to be able to scale it up to a correct size so that it doesn't look too small
zsouthboy
by zsouthboy » Fri Jun 27, 2008 7:55 am
Looking better neo.
Now take it off the atrocious brick texture and out of the sunlight and stick it in some studio lighting
by neo0. » Fri Jun 27, 2008 9:21 am
Thanks for the advice.
How do I use a bump map to remove the flat look.
The texture is very hi res, i could scale it down.
What is studio light and how do I add it?
arneoog
by arneoog » Fri Jun 27, 2008 9:52 am
Studio Light.. well
You could do it like this:
(one redish, one bluish and, if you like, a white light, all with a slopy background)
hope it helps ^^
- Studio Setup
- studio_setup.jpg (102.97 KiB) Viewed 3184 times
Users browsing this forum: Majestic-12 [Bot] and 30 guests
