Cannot find bump map texture
I browsed to the actual location of the material and when I tried to render it said "could not find map for material 2."
Re: Cannot find bump map texture
Has anyone else experienced this error?
Try moving your texture to a different folder, then browsing for it again. If this solves the problem, please post the path name that wasn't working.
Didn't fix it.. I am using the leather material from the DB.. Except I changed the color of the diffuse map slightly.
Works fine for me, neo
Try creating a new material from scratch and then loading the leather material. Any problems?
If you can give me a precise set of repeatable steps that cause the error, maybe that would help me sort it out.
Users browsing this forum: No registered users and 46 guests
