I can't make a bump material... Please help me!
- nicolaragni@hotmail.it
I have tried to change the bump parameter in the material editor window with a texture material, but i always have a smooth surface...
I have to make the stucco wall and the brick pavment..
Sorry for my "italian" english Thank you!
- All the surfaces are too smooth!
- im1231938057.jpg (95.71 KiB) Viewed 4681 times
I specified the B parameter but seems don't work.....
The material get darker and... strange!
Looking for some good tutorial I found a very nice one made by Whaat that explain everything I neet to know about Skindigo.
Thank you eulgrand for your reply..
- Untitled-1.jpg (202.38 KiB) Viewed 4622 times
- kellpossible
Ciao Nicola! Un tutorial sarà rilasciato a breve, tranquillo, ci sto lavorando
Innanzitutto, che skindigo usi?
Poscia, l'effetto è giusto, solo che hai messo un valore di bump troppo alto: tenta con un valore molto più basso, tipo 0.003/0.005: skindigo è MOLTO sensibile ai valori di bump.
Su che cosa gradisci il tutorial, in particolare?
Hi Nicola! A tutorial will be released soon, don't worry, I'm working on it
First of all, Skindigo version?
Then, the bump effect is all right: simply your bump value is way too high: try with a much lower value, 0.003/0.005: skindigo is VERY sensible to bump values.
What topic do you wish the tutorial would cover?
As Pibuz said
The <b> parameter is in meters, so 90% of the time values are under 0.1. Being subtle, bump mapping needs longer renders than you posted to be visible; to test it remove other objects in scene, or apply to them a gray diffuse. The test is faster if you remove all color information in scene (bump only).
24 hours of render and now it's all Ok!
I found some Whaat's tutorials so i understand the meaning of all parameters...
Now i'm beginning to enjoy this way of work!
Thank you Pibuz.. I'm using a 1.0.9 Skindigo version.
I'd like to see how to import the materials came from indigorenderer.com or a practice guide about the xml way to set up a scene and materials.
24 ore di render ed ora comincia ad andare bene...
Ho trovato qualche tutorial postati da Whaat e finalmente ho capito a cosa servono tutti i parametri del material editor.
Adesso comincio a divertirmi!
Grazie Pibuz... (Scusami ma sono un super principiante!)
Sto utilizzando la versione 1.0.9 di skindigo.
Per il tutorial, potrebbe essere un'idea averne uno circa l'importazione dei materiali scaricati dal sito... Oppure qualcosa riguardo alla programmazione dell'xml per i render ed i materiali, cosa che per me è ancora cinese!
A meno che ovviamente non ci sia già qualcosa...
Grazie infinite!
Grazie infinite!
- im1232102271.jpg (96.2 KiB) Viewed 4563 times
Ehi, buon risultato nicola!
Senti, una cosa che potrebbe aiutarti: hai usato exit portals per questo render? Sono utilissimi per ridurre il tempo di calcolo per gli interni..
Riguardo al settaggio scena e materiali via xml: credo nn sia troppo necessario che impari come si fa, dato che SkIndigo è fatto apposta per trasformare gl input della gui proprio in linguaggio xml!
Te lo dico perche anche io, che lavoro con indigo da un paio d'anni, nn so ancora scrivere in xml..
Ehi Nicola: nice result!
Listen, something that could help you: did you use exit portals for this render? They're very useful to reuce render times for indoor scenes..
Concerning scene and material settings via xml: i don't think you really need to learn how to do it, given that SkIndigo does the work for you (you set parameters via the GUI and it translates the data into Indigo language)
I tell you because I work with Indigo and SkIndigo since two years, and I still can't write in xml language..
Users browsing this forum: No registered users and 83 guests
