by neo0. » Sat Jun 21, 2008 11:39 am
Hi
, so far I havent been able to get good caustics with glass...
1) Does tranparency sof the glass matter?
2) Does thickness of the glass mater? Can I get decent caustics with solid glass objects?
3) What light source/render method is best for caustics? Is thae standard sky light with MLT good enough?
EDIT : I attached my render attempt. Caustics are really faint. Render time is a bit over an hour.
- im1213997985.png (844.98 KiB) Viewed 1900 times
aleksandera
by aleksandera » Sat Jun 21, 2008 12:52 pm
What the hell is this?!
Go find some photography lightning tutorials and than
try a simple glass shape. If you are trying to do some scifi,
you dont need indigo renderer.
Chears!
Aleksander
by OnoSendai » Sat Jun 21, 2008 1:03 pm
Try giving the glass less absorption.
by neo0. » Sat Jun 21, 2008 1:45 pm
My sss is turned off for each glass material. Im using the skindigo glass preset here.
by Whaat » Sat Jun 21, 2008 2:33 pm
OnoSendai wrote:Try giving the glass less absorption.
= lower your opacity setting to less than 5.
by Kram1032 » Sun Jun 22, 2008 6:44 am
at your solid-glass-question: You actually SHOULD use solid objects
everything else might be incorrect.
