MAterial Database Question
Where do I need to put the files for when I download a texture from the mat database?
version 1.1.5 has the best IGM support. it will continue to improve over time. You'll have to have some patience as the kinks get worked out. The biggest problem is that many of the materials that are currently in the database are not valid IGM files so they might not load properly in SkIndigo.
Be sure to download Indigo 1.1.5 if you are using SkIndigo 1.1.5
