Is there a way to know that your material assignment in skindigo was successful? Should the changes be displayed in sketchup?
EDIT : Where could I find more material presets?
no, there is no way to know for sure that your settings are applied in SkIndigo -- there is no apparent change to the appearance of the model, there is no confirmation window or anything like that. once you enter a value into you skindigo material editor interface it is saved into your model automatically.
and as for other presets ... nowhere at the moment. there is a way to save and load presets from skindigo, but no one has really gotten a collection going. soon the material database on the site here will be up and then you will have all of those at your finger tips.
Would it be possible to have some sort of a window that shows you what material is assigned to what object, maybe like a node graph or something? Like where you've got your materials on one side and your objects on the other, and you can just connect nodes to assign materials? just an idea.
Is there a place where we can request materials for the library?
yea i think you need to know the cauchy b and the ior... sss dunno. google should be able to find some numbers for you if you arent having any luck here in the forum... im sure some of this stuff has been covered previously. its just a matter of finding it.
for glass id use the skindigo preset, you could optionally add the cauchy b number of 0.003 if you wanted. itll slow down render speeds tho ;/
cheers
cheers
