ARK
by ARK » Thu May 29, 2008 7:54 am
Hi
Is it possible to make a material two sided in skindigo?
The image i´ve posted is a little grainy, and it just at test of at grass field, but the backsite of some of the faces becomes visible.
The grass is made with a face and a simple texture and clip map.
I´ve tryed to search the forum but whitout luck!
Thanks! Indigo Rocks
- im1212001732.png (239.05 KiB) Viewed 2120 times
by Kram1032 » Thu May 29, 2008 8:53 am
Is it actually possible to get single sided materials with Indigo? O.o
by Whaat » Thu May 29, 2008 11:07 am
could you post the skp please? you probably have to put it in a zip file first
cpfresh
by cpfresh » Thu May 29, 2008 5:39 pm
it looks to me like your ground plane is just showing thru, but at this resolution it is difficult to see for sure. i did a quick test and i cant seem to reproduce your back-face issue ... mine render ok.
- straight to indigo
- im1212038731.png (415.45 KiB) Viewed 2049 times
- my skp model
- im1212038731-skp.png (62.74 KiB) Viewed 2049 times
ARK
by ARK » Thu May 29, 2008 7:06 pm
Thanks for the replies!
Yes cpfresh that's the way I made the grass.
I just tryed again but I still get to see the backfaces
I've attached the sceen file - hope someone can tell me where I made a mistake.
ARK
by ARK » Thu May 29, 2008 7:10 pm
And... here the attachment!
- GRASS_DENSE.zip
- (257.1 KiB) Downloaded 232 times
