Hey all! Here is the supplied IGS file (from the new material database thread) re-worked in-order to work with sketchy. I believe its original author is either drBouvierLeduc or fused ... Thanks for sharing! To use this in SkIndigo, all you need to do is unzip it to your SUPreviews folder.
**I'd recommend saving your current IMPmatdb.igs file some place for safe keeping [or rename]**
Then to use it for previews just select the 'Indigo' model on the SkIndigo Material Editor GUI. Easy!
If anyone uses this and makes it better in some way, please update this thread with your changes so everyone can enjoy them!
**edit**
Here's a wood texture I tested using the IMPmatdb.igs file.
Material Preview Scene for SketchUp/SkIndigo
- a wood texture i tested
- Bebeere_c.png (367.86 KiB) Viewed 2447 times
- SU-material-preview.zip
- the zip file containing the IGS and the subsurface scattering image. the other images should already be in your textures folder.
- (1.32 MiB) Downloaded 337 times
worked for me, even if ti is going to change.
this is straight skp tile,
but when i did this it showed those little squares, minor bump and minor exp. using same mat.
Thanks CPFresh!
hey Whaat,
neato Custom preview!
Thanks CPFresh!
hey Whaat,
- bluetilecustom.png (81.21 KiB) Viewed 2410 times
- bluetile.png (397.22 KiB) Viewed 2413 times
Users browsing this forum: No registered users and 76 guests
