Changelog:
Updated installer for Sketchup 2016.
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 8.25.6.rbz
http://www.indigorenderer.com/documenta ... o-rbz-file
Windows Installer:
Note for Sketchup 2016 users: The SkIndigo extension may need to be enabled in the Preferences. Please refer to the installation instructions.
Let us know if you hit any bugs!
SkIndigo 3.8.25.6
- afecelis
Re: SkIndigo 3.8.25.6
Thanks for the updated version Fused
Hello Fused,
I have managed to install the Skindigo plugin for SU 2016. For some reason, the Render Settings window will not open. The Material Settings window works fine.
I am using an iMac, OS X El Capitan. Everything worked fine with SU 2015. This is the message I get in the Ruby Console window when I click on the Render Settings button:
Error: #<Errno::ENOENT: No such file or directory - /Applications/Indigo Renderer/data/camera_response_functions>
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoRenderSettings.rb:727:in `open'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoRenderSettings.rb:727:in `entries'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoRenderSettings.rb:727:in `get_camera_response_functions'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoSettingsEditor.rb:521:in `refreshCamResponseList'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoSettingsEditor.rb:298:in `refresh_dialog'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/IndigoSettingsEditor.rb:311:in `show'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/skindigo_core.rb:664:in `render_settings'
/Users/michele/Library/Application Support/SketchUp 2016/SketchUp/Plugins/skindigo/skindigo_core.rb:2913:in `block in <top (required)>'
SketchUp:1:in `call'
Hope you can help!
Michele
Hope you can help!
Michele
Hi Michele, other,
The error above is fixed in 3.8.29.1: http://www.indigorenderer.com/forum/vie ... 17&t=13777
