SkIndigo 3.8.6.1
Re: SkIndigo 3.8.6.1
Updated build:
Added searching for textures in scene directory when external texture path is invalid.
Getting this error now;
SkIndigo version: 3.8.6.1
SketchUp version: 8.0.11752
Ruby platform: i386-mswin32
Ruby version: 1.8.6
Error during processing: wrong number of arguments (2 for 3)
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:514:in `export_base_emission'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:514:in `write_mat'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:118:in `export_material'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/IndigoExporter.rb:1756:in `export_environment'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/skindigo_core.rb:217:in `export'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/skindigo/skindigo_core.rb:2568
Ruby version: 1.8.6
Updated build with fix.
When you export a material with an opacity set to less than 100 this used to export as a blend between diffuse transmitter & diffuse, this now seems to export as a blend between 2 diffuse transmitters.
Updated build with fix.bubs wrote:When you export a material with an opacity set to less than 100 this used to export as a blend between diffuse transmitter & diffuse, this now seems to export as a blend between 2 diffuse transmitters.
I don't think the 'LinkedIGM' is working with .igm files... only seems to work with .pigm files.
I'm getting an error about missing materials with .igm
Seems to work fine here. Can you send a scene (.skp + .igm) showing this problem?bubs wrote:I don't think the 'LinkedIGM' is working with .igm files... only seems to work with .pigm files.
sorry my mistake, it was a bad material... working fine
- Antonis777
Re: SkIndigo 3.6.8.1
Got the same messageak-sam wrote:My first attempt is attached to this post - densities are about 2000 and 4000 for the 2 types of grass.
I've added a curved surface instead of a flat one, and added two more types of scattered object (total is now 4).
I get this error:
An error occurred while SkIndigo was exporting the scene.
Please copy and paste the following details into an email to support@indigorenderer.com:
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Ruby version: 2.0.0
Error during processing: undefined local variable or method `object' for #<IndigoMeshBuilder:0xed54210>
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:885:in `get_dummy_defn'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:638:in `build_linearised_definition_info_for_instance'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:699:in `block in build_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `each'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `grep'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:698:in `build_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:668:in `get_linearised_definition_info_for_def'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:747:in `process_component_instance'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:848:in `block in process_entity_list'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `each'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `grep'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:847:in `process_entity_list'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:868:in `process_entities'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:184:in `export'
C:/Users/sac/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:2533:in `block in <top (required)>'
-e:1:in `call'
Antonis: try a more recent build: http://www.indigorenderer.com/forum/vie ... 17&t=13250
please help me guys
SkIndigo version: 3.6.28.3
SketchUp version: 8.0.3117
Error during processing: undefined method `downcase' for nil:NilClass
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1314:in `exported_texture_filename'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1027:in `export_texture'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:292:in `write_mat'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:90:in `export_material'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:968:in `export'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:967:in `each'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:967:in `export'
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:3414
D:/PROGRAMS/GOOGLE SKETCHUP/Plugins/skindigo/skindigo_core.rb:1476:in `call'
kreen: you are using an old SkIndigo version, please try the one from the first post of this thread.
Users browsing this forum: No registered users and 72 guests
