Download Trial Buy now
Search  | Login  | Register
Post new topic Reply to topic  [ 2 posts ]
Offline
I've tried out the perforated aluminum, but all I got was a glass-looking texture. I need a weathered steel/metal/corten curtain wall, i.e. De Young Museum [http://lh3.ggpht.com/-lL8Btl4-SE0/SXOnv6Co59I/AAAAAAAACrw/O5OBwF9qNiU/DSCN2456.JPG], rendered out for a studio project. But I have no idea how to make materials...Any suggestions?
Also - when applying perforated materials, how should I make the masses? I know that 2D surfaces are a no-no, but how do the perforated holes appear on a 3D object?
 Profile
Offline
Sounds like the repetition was too high, leading to sub-pixel features possibly. Try again after tweaking the geometry UVs; you can also change the Rotation/Scale settings in Indigo's texture window for a similar result (when dealing with blend textures that is). For instance instead of :
1 | 0 | 0 | 1
try:
0.01 | 0 | 0 | 0.01
There is this Indigo material called "null" wich does just... nothing. Blended with a metal material it would figure the holes by transparency. It is the method this perforated material is using, only that a procedural shader stands for the blend texture.
_________________
it's magic
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
