Hi
I got this error message:
Error: Scene parsing error: Syntax error while parsing real 3-vector from 'nan nan nan'
and i have no idea how to fix this, or even find what the problem is. I looked through materials and components, but found nothing.
Any idea?!
scene parse error
Re: scene parse error
Hi rainyday, can you please state the SkIndigo version that you are using ?
A linked skp scene may help. If you are familiar with the scene debugging process, you could strip the scene to the object or material incriminated.
sure, it's version 3.0.14
but now i have a new problem (too?):
Error: Scene parsing error: Error while binding material '*Concrete-rough*2' to geometry '*Concrete-rough*2': No such material defined '*Concrete-rough*2'
but i can't figure out how to define this one either!
no, i'm a newby at renders
no idea about the scene debugging process
It consists in pruning elements (geometries and materials) from the scene until the error is gone. The last element removed was therefore in relation with the error. Do not worry about this tho, Whaat can handle
Get Indigo 3.2.3, it ships with an updated SkIndigo. The last error at least could be fixed so.
Whaat will tell wether a scene or sample is required, thank you.
