Hi Whaat and (Sk)Indigo friends,
I recently encounter an issue using Indigo and Skindigo (both latest version).
This is the error message I get when pushing the render button.
Error: Scene parsing error: Error while binding material 'tiles ' to geometry 'Group#565': No such material defined 'tiles '
Any suggestions?
Thank you in advance,
Kwistenbiebel
Scene parsing error
Re: Scene parsing error
my 2 centskwistenbiebel wrote:Hi Whaat and (Sk)Indigo friends,
Any suggestions?
Kwistenbiebel
check material name --> 'tiles ' or 'tiles'
- kwistenbiebel
Thanks Snorky,
I tried that. There is indeed no 'tiles' material and making one with that name doesn't solve it..
but, is there a material called "tiles_" (replace the underscore by a blank space included in the name). Indigo is looking for a material called
tiles+[blank space]
tiles+[blank space]
Your problem might come from a material registered by a component, it's a known issue. If I remember correctly, one solution was to explode components in order to find the culprit.
You will find a thread where the error is discussed in the SkIndigo forum.
Cheers
Cheers
- kwistenbiebel
Re: Scene parsing error [SOLVED}
Thank you so much CTZn...solved!
I spotted the 'tiles ' SU material, renamed it 'tiles_' and that fixed it.
Simple solution, Tx
Simple solution, Tx
