I can't seem to get SKIndigo to work at all with Sketchup (8)
Whenever I press render or open an exported scene in Indigo I get the following error:
SceneLoaderExcep: Found unexpected element 'material_id_tracer'. (In element 'renderer_settings', around line 12, column 9)
Indigo version: Indigo Renderer v2.6.1, Windows 64-bit build.
Exporter: SkIndigo version:3.0.14
Platform: i386-mswin32
Author: Administrator
Description:
Date created: Thu Sep 01 14:01:52 +0200 2011
Error, Skindigo not working at all
Re: Error, Skindigo not working at all
You need to have use a Skindigo exporter version that is compatible with the version of Indigo that you are running.
You are trying to feed Indigo 2.6.1 with Skindigo 3.0.14 and that is asking for trouble. You need to install Indigo 3.0.14 to resolve this issue.
Also you seem to use Indigo 64bit against a 32bit OS ? If that's so you need a 32bit Indigo.
Thanks for the reply, I'll try getting a new version.
I'm not running a 32bit OS however, I don't know why it indicates that. I'm running Windows 7 64-bit.
Okay. Headroom made a point indeed.Jenovation wrote:I'm not running a 32bit OS however, I don't know why it indicates that. I'm running Windows 7 64-bit.
Users browsing this forum: No registered users and 130 guests
