I installed sketchup 8. I downloaded "indigo.osx.2.4.13", "2.4.13-SkIndigo" and inside this folder there is this txt file:
"INSTALLATION
This version of SkIndigo Should Be Used with Indigo 2.4.13. Also it MAY work with more recent versions Indigo as well.
1. Any previous versions of SkIndigo Remove from your SketchUp / Plugins directory
2. After unzipping the file you downloaded, you Should Have Called to file 'skindigo.rb', and a folder Called 'skindigo'.
3. Copy 'skindigo.rb' into your SketchUp / Plugins directory (on Mac OSX: Libary / Application Support / Google SketchUp 7/SketchUp/Plugins)
4. Copy the 'skindigo' folder into your SketchUp / Plugins directory (on Mac OSX: Libary / Application Support / Google SketchUp 7/SketchUp/Plugins)
5. Run SketchUp
6. If Prompted, locate 'indigo.exe' (on Windows) or 'Indigo.app' (on Mac) "
Where is this folder? "Libary / Application Support / Google SketchUp 7/SketchUp/Plugins"
I can not find it. !!!!!!!
Can anyone help me?
skindigo mac. where is the folder !!!!!!! HELP
- compadrelucas
Re: skindigo mac. where is the folder !!!!!!! HELP
hope this helps. look at the mac finder path, you'll see where you are supposed to place your skindigo.rb file as well as your skindigo folder (wich contains all of the necesary resources for precious skindigo to work).
- compadrelucas
You do know what the users/library folders are, right?
compadrelucas wrote:hope this helps. look at the mac finder path, you'll see where you are supposed to place your skindigo.rb file as well as your skindigo folder (wich contains all of the necesary resources for precious skindigo to work).
Thank you so much! I found the folder. Thanks a lot!!
- compadrelucas
cool.
keep us posted on your progress!
