Skindigo Spectrum Picker not working.
So the Skindigo Spectrum Picker (at Albedo/Constant Map) is somehow not working for me. I cannot pick any color, only black. If I pick any color in the spectrum box and click accept, there comes an windows sound for "mistake" and the color returns to black. The same happens when i manually pick RGB values.
SketchUp 8 / Windows 7 x64 / Indigo 3.0.14 / i7 CPU Q720 @ 1.60 GHz / 4.00 GB RAM / NVIDIA GeForce GT 230M
Re: Skindigo Spectrum Picker not working.
The picker seems to be broken for all the functions which use it. I alreasdy reported that to Whaat. Thanks!
If you change one of the values of RGB to something unequal zero, pick the color with the colorpicker, push the little button in the right bottom corner and accept the dialog after that, the color is transferred to the main material window. Perhaps a little workaround until whaat will fix it
Cotty
Cotty
hmmm...try first setting the magnitude to 1.0? and then picking your color.
mmmm ok We'll try that Dale.
Should be put as default, btw, don't you think?
