Download Trial Buy now
Search  | Login  | Register
Post new topic Reply to topic  [ 11 posts ]
Offline
Can anyone explane types of glass, and how can someone use all type of glass, because only thine glass doesn't appeare black.
THANKS
_________________
Sketchup 8
Indigo 3.6.8 | Skindigo 3.6.7
i5 3550k @3.3Ghz | GTX 660 Ti 3gb
 Profile
Offline
Hello,
Non-thin glasses are meant to be applied to volumes only.
This means, if you want to make a sheet of glass, for instance in a window, you must model it as a cube (and not as a single polygon) with some thickness (standard glass sheets have 4mm to 10mm thickness). Otherwise, it will appear black.
Etienne
_________________
Eclat-Digital Research
http://www.eclat-digital.com
 Profile
Offline
Galinette is correct (as always) - if you want to use any glass other than the 'thin glass' then you need to have a volume, ie draw a box in sketchup and apply the glass material to both sides for it to work. If you apply glass to a single plane in sketchup it comes out black and shiny.
I think thin glass is quicker to render though? But won;t give you quite as realistic results as a proper glass material
See below, on the right is a single pane, renders black - on the left a volume (box) renders like glass.
 Profile
Offline
only because you render it from behind /normals facing inside). from the other side you have a different result ;)
_________________
Cindigo user - My Portfolio
AMD 1090T @ 6x3.6Ghz on Vista64
 Profile
Offline
BY THE WAY, you get an incorrect result if you apply a specular shader to planar geometry.
Some time ago I had a very interesting discussion with Thomas (aka Lycium): he told me to try and use only the specular shader, instead of the Thing Glass. He strongly supports the correspondence between reality and modeling, because this points the rendering engine's development unidirectionally towards realistic algorithms and less to biased shortcuts, so the result can be more real-like. A good exemple can be the new "architectural glass" algorithm.
To make a long story short, always model volumes, because glass can be only tridimensional. 8)
_________________
visit my blog! (italian language)
www.filipposcarso.blogspot.com
 Profile
Offline
Not me squire! See below, the glass preset comes out black and shiny even if applied to the correct face on a single plane.
The red arrow is just for orientation so you can see I've rotated the view to show the back face (pure black as you know) The other box obviously shows the glass preset applied to a volume where it works correctly.
 Profile
Offline
Thank you all, very much. You have helped me a lot.
_________________
Sketchup 8
 Profile
Offline
Interested stained glass and grass. Maybe a little too much DOF, and underexposition.. Could you make a lighter version? :mrgreen:
_________________
 Profile
Offline
can you explain me what do you mean by DOF and expo... Jes i can make brighter version :) Thanks
_________________
Sketchup 8
 Profile
Offline
DOF = Depth Of Field, which basically means the distance put on focus. Higher number (e.g. f/22) results in clearer objects (I'm simplifying A LOT), low numbers (e.g. f/2) result in more out- of-focus objects.
Increase the ISO value to adjust the exposure: higher numbers mean lighter image.
_________________
 Profile
Offline
THANKS
_________________
Sketchup 8
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
