this is a neophytes attempt at doing some photo realistic renderings so bear with me...
I tried reading the other post but no solution.
While in Sketchup 8 I press "render scence" then the Indigo app pop up with a blank screen. I notice towards the bottom it reads loaded, so I press the "green" play button located in upper left hand corner....
then i get this...
SceneLoaderExcep: Found unexpected element 'glass_acceleration'. (In element 'renderer_settings', around line 12, column 9)
Indigo version: Indigo Renderer v2.4.13, OS X 64-bit build.
Exporter: SkIndigo version:2.6.1
Platform: i686-darwin8.10.1
Author: balensd
Description:
Date created: Sat Jan 22 23:20:19 -0600 2011
Please contact support@indigorenderer.com.
Any help would be great!
Running on MBpro OSX 10.6.6
sketchup 8
Installed Indigo2.4.13
installed Skindigo 2.6.1
Found unexpected element 'glass_acceleration' ??
Re: Found unexpected element 'glass_acceleration' ??
You have to use Indigo 2.6.1 with Skindigo 2.6.1
Currently you have Indigo 2.4.13 and Skindigo 2.6.1. Your Indigo version is too old for the exporter.
Thanks for such the quick response. Will try installing newer version.
