I'm trying to render a scene made in SU8, where the view is quite far away. Under SkIndigo Render Settings, I have selected View option under Image Dimensions. When exporting the scene in Indigo renderer the output image is different from the view I had in SU. In my case it's much more zoomed inn. Does anyone have a clue how to solve on this problem?
Tanks for any helpful tips!
Sketchup view doesn't coexist with exported view
Re: Sketchup view doesn't coexist with exported view
hi,
did You use 'apply to model' or 'apply to scene' button after settings output dimensions?
You are probably trying to render a parallel projection view, which Indigo does not support. If you switch your SketchUp view to perspective, it should work.
Case solved! Thank you for great help!!
Users browsing this forum: Majestic-12 [Bot] and 91 guests
