can't convert nil into String
hmmmm...did you try to install the new version of SkIndigo 2.4.8? Make sure you install it to the SketchUp 8 plugins folder.snorky wrote:Code: Select all
sorry for my incomplete post.Whaat wrote:hmmmm...did you try to install the new version of SkIndigo 2.4.8? Make sure you install it to the SketchUp 8 plugins folder.snorky wrote:Code: Select all
When I did this, everything worked perfect. Are you on Mac or PC? (I haven't tested Mac yet with SU8)
load 'skindigo.rb'
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:624: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:655: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:1481: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:1850: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:4708: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:6848: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:6851: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:7354: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:7464: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:7477: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:7490: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:7510: warning: don't put space before argument parentheses
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:10: warning: already initialized constant VERSION
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:11: warning: already initialized constant VERSION_
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:12: warning: already initialized constant RELEASE_DATE
Error: #<TypeError: C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:945:in `join': can't convert nil into String>
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:945:in `get_indigo_path'
C:/grafica/Google SketchUp 8/Plugins/skindigo.rb:5288
(eval):945:in `load'
(eval):945
Yes, SkIndigo should not stop loading if it finds no Indigo path.snorky wrote:Whaat, can you tell me where I manually enter the indigo path!??!?!!?
I think the problem is the save path routine
skindigo must start anyway, but stops if it no finds the path: I think that is incorrect
sorry for poor english.
I tried.Whaat wrote:Yes, SkIndigo should not stop loading if it finds no Indigo path.snorky wrote:Whaat, can you tell me where I manually enter the indigo path!??!?!!?
Do you have Indigo installed in your Program Files folder? It doesn't have to be installed there but I suggest you try to install it there and then see if it works.
Please let me know.
Thanks.
Hi,unclex wrote:can't convert nil into String
me too
why?
I don't know, 7 was uninstalled.....Whaat wrote:Hi,unclex wrote:can't convert nil into String
me too
why?
Is this error only with SU8 for you as well?
Thanks.
Users browsing this forum: Majestic-12 [Bot] and 100 guests
