Log in or Register
Post new topic Reply to topic  [ 14 posts ]
Offline
Cindigo 2.0
for Indigo 2.0
Quote:
Cindigo 2.0 R9 - PC
Download: Installer | Archive
~3 MB, x86 only
Quote:
Cindigo 2.0 R10 - PC
~3 MB, x86 and x64
Quote:
Cindigo 2.0 R11 - PC
~3 MB, x86 and x64
Quote:
Cindigo 2.0 R10 and higher - Mac
Download: Archive
~3 MB, x86 only
Make sure you have the newest version of quicktime installed!
Good beginner tutorials can be found here (german and english, a bit outdated), a video tutorial for beginners here
The Cindigo Blog
changelog wrote:
Cindigo 2.0 Stable
* indigo instance will now be selected when created without a selected object
* deform mode for indigo instances fixed (does not render/export anymore when disabled)
* cindigo will always detect the scene scale, even if no indigo render settings present
* previews will always launch in the indigo GUI (temporary)
* re added animation export (static animations only)
* aperture diffraction default back to post process
* changed default sun direction
* changed indigo instance drawing mode default to "object"
Please tell me if you find bugs or have specific requests. i will try to fix/implement as fast as possible.
 Profile
Offline
Good work fused, as usual lightning fast 8)
I'll have a proper look at this during the weekend, I just set up my new AMD Phenom II X4 945 (95w) with 4x3Ghz, so some testing will come anyway :)
_________________
C4D User - My Portfolio
iMac 2x2.8Ghz on Vista64 & AMD 4x3.0Ghz
 Profile
Offline
Erm,
I can only choose "render with Indigo"... and the scene is exportetd as "quickrender.igs" somewhere to the program package structure.
Am I not able to export my scene where I want to anymore?
 Profile
Offline
You can specify a path in the export settings, first setting there :)
Since you nearly always export your scene to the same path, this one saves some clicks during export!
_________________
 Profile
Offline
Ah, didn't discover this yet... great!
Another question: is it possible to specify the *.igi output path, too? Or can it be automatically be saved in the same place like the *.igs? That would make much sense in my opinion...
 Profile
Offline
no, but the next version will feature exactly this. either standard path (renders), custom path for png, exr and igi or the scene export path (only if its not exported to the quickrender).
 Profile
Offline
Very cool! :D
 Profile
Offline
Hey fused,
why can't you provide a 64bit-version (R10.5 & R11, Mac) of Cindigo?
Is it because of XCode or any lacking information of Apple? Or a missing 64bit-Mac? Could I or anyone help you out in any way?
I am not fronting you, please don't get me wrong!
I am just wondering about that, because I read it in Albert's review...
_________________
ZENTAPHER.COM :: ONLINE PORTFOLIO
Indigo 2.2.12 | Cindigo 2.2.9 | C4D R10.5 | Mac OS X 10.5.8
 Profile
Offline
heh, there is a much simpler explanation for it: i has just never crossed my mind that i could make a 64bit build of the mac version :D
i would have to move the minimum requirements from R10 to R10.5 tho.
(i dont have a mac at home and cant make 6 different builds like for the pc version, because i have to make them at work)
 Profile
Offline
Hi fused, great work as allways, just one thing, when I launch the preview Indigo's window opens instead of Indigo console, can you check it?
 Profile
Offline
Did you read the changelog? fused is already aware of this :idea: but thx for reporting anyway! 8)
_________________
My Portfolio
 Profile
Offline
oops! sorry I didn't notice the changelog :oops:
 Profile
Offline
Imagine you have thousand of instances in box mode, but each time you select one of those it would change to object mode... just imagine ;)
_________________
1.1.1, the number of the beast!
 Profile
Offline
hmmm, sounds like a cool idea :)
might implement it!
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
