Onfame
by Onfame » Tue Oct 28, 2008 9:12 am
As you can see in Cinema the Textur is normal but in Indigo it is turned about 180 degrees in the y-axis direction, i dont know why? i tried to turn the texture in gimp around 180 degrees but it didn´t affect the result, also i tried uvw-mapping and cube mapping, but nothing happened. Any ideas or am i just stupid?
- Rendered in Indigo
- indigo.jpg (4.13 KiB) Viewed 3503 times
- Rendered in Cinema 4d
- Cinema.jpg (4.48 KiB) Viewed 3505 times
by Kram1032 » Tue Oct 28, 2008 9:21 am
AFAIK it's a known bug with the exporter.... mirror your texture and it should work fine...
by fused » Tue Oct 28, 2008 9:27 am
true.
its a known bug. will be fixed in the next version.
Onfame
by Onfame » Tue Oct 28, 2008 9:39 am
Hmm as i said i tried to mirror it, then i deleted the old material and made a new one, hmm maybe it is a cinema fault?
- cinemafault.jpg (76.23 KiB) Viewed 3497 times
by fused » Tue Oct 28, 2008 9:45 am
yes, thats a c4d problem. theres a relaod button somewhere, but for some reason this doesnt work either when you copied the image to the document location (when c4d asks you).
Onfame
by Onfame » Tue Oct 28, 2008 9:47 am
crap i deleted the whole Material, and made a newone but nothing happened
doesnt matter, it were just 5 minutes work for the scene so i make a new one
by PureSpider » Tue Oct 28, 2008 10:15 am
I can smell Mario here?!
by PureSpider » Tue Oct 28, 2008 10:29 am
Nice
