Texture Woes
- pixie
Texture Woes
The textures aren't being applied as they should.
- txtwoes.zip
- scene
- (171.45 KiB) Downloaded 263 times
Re: Texture Woes
Hi Pixie.
Use only one UVW tag for all the volume, like the attachment; then resize the repetitions of the texture from the matrerial tag:
- txtwoes_modified.rar
- (105.6 KiB) Downloaded 243 times
- pixie
Re: Texture Woes
I know how to work around it But i don't want to connect the objects i have, i just want it to behave as C4Dyonosoy wrote:Hi Pixie.
Re: Texture Woes
Hi.
In the case above no thing is connected; but more simply, change the texture tag from UVW to cubic and is done.
Is the last shoot for this. Bye.
- pixie
Re: Texture Woes
Well thank you by the time you spent giving me a solution. When I want to position a texture I don't go to the uv and resize or offset it, I use whichever mode I feel best, cube, flat, sphere... and then I generate the UV map, and assign if I want to update it, since I am not able to do it, sadly it's not of much use to me (this is a rather simple example, it would a bit cumbersome to apply this solution in the project which I'ma having the problem). I also think that the ultimate goal of Indigo for Cinema is to provide a seamless usage, without the need of gimmick for doing what is intended.
Still many thanks to you.
Re: Texture Woes
If you'd like an atypical solution, you might try using SketchUp for simple UV assignment. It's much easier, and you can just export it as a DAE file and reimport back into Cinema 4D
Re: Texture Woes
Fixed for the next cindigo release.
