[BUG] motionblur with render instances...
- zeitmeister
... doesn't work; render instances aren't being displayed.
Scene tree:
- Null object (animated, MB-tag)
--- model
--- render instance
--- render instance
Latest Indigo, latest Indigo for C4D, C4D R14, Mac OS.
Could this be fixed? Would be awesome!
I need this to do automotive rig shots...
Scene tree:
--- model
--- render instance
--- render instance
Re: [BUG] motionblur with render instances...
Would it be possible to get an example scene for this specific problem?zeitmeister wrote:... doesn't work; render instances aren't being displayed.
Scene tree:
--- model
--- render instance
--- render instance
I may have on by ZomB that shows a similar problem but it'd be good to have one that shows the exact problem you are having.
- zeitmeister
Few minutes...
- zeitmeister
Attached.
Just switch the instances to regular instances and it works...
it really happens only with render instances.
- mb-instance_bugscene.zip
- (77.62 KiB) Downloaded 371 times
zeitmeister wrote:Attached.
That's so strange. Looking into it.
You can just work around it by not using C4D render instances then, it doesn't make a difference for Indigo anyway.
- zeitmeister
... but it does in C4d! )
This looks a bit better doesn't it?
Still the same limitations as before (only keyframed animation, etc) but it works for render instances now.
- zeitmeister
Yeah, fantastic!
Thanks a lot!
Thanks a lot!
Users browsing this forum: No registered users and 52 guests
