by fused » Wed Mar 13, 2013 3:17 am
There is a know issue with R13 and possibly R14 that the alpha channel (when rendering foreground alpha or using the shadow pass) will not be saved by C4D.
by CTZn » Wed Mar 13, 2013 3:43 am
fused wrote:* Added support for invisible to camera.
Hah. Clearance rank 3 pending
edit: ah no hold on... pixiiiiiiie heeeeelp !!!!!
edit2: all good now, you owe me one pixie though
Good job I assume !
CTZn on Wed Mar 13, 2013 4:27 am, edited 1 time in total.
wlf_alex
by wlf_alex » Wed Mar 13, 2013 3:51 am
Fantastic ! Thanks а lot !
ritter
by ritter » Wed Mar 13, 2013 3:54 am
Thank you !
by pixie » Wed Mar 13, 2013 6:11 am
CTZn wrote:fused wrote:* Added support for invisible to camera.
Good job I assume !
Pixie is here for the rescue! xD Sadly Pixie couldn't make it work.
PS. Pixie's desire was just to click on the red 'visible in editor' and make it simply work. Nor the tag applied on the scene.
P.S.S It works inside the Cinema 4D, bummer!
by zeitmeister » Wed Mar 13, 2013 6:36 am
Very cool, thank you Yves!!!
by CTZn » Wed Mar 13, 2013 7:17 am
pixie wrote:Pixie is here for the rescue! xD Sadly Pixie couldn't make it work.
There was only the API method implemented in
Indigo 3.6.9 for invisible_to_camera support I'm guessing.
Cheers
Ilay
by Ilay » Sun Mar 17, 2013 8:04 am
Hello Yves
Can post image or sample?
* Added option to share a medium with another material (experimental).
I'm sorry for my bad English
by Zom-B » Mon Mar 18, 2013 1:14 am
Ilay wrote:Hello Yves
In the Medium Section of a material on the top you have that field wehere to drag & drop the material to share the medium with!
This is needed for some setups where you have for example one glass object, but with one side of it a frosted glass (using a glossy transparent material). Such glass object would need to have the same medium for both materials to render correctly
Ilay
by Ilay » Mon Mar 18, 2013 4:24 am
Thanks Arthur .... Спасибо.
Honestly i don't understand. Can you show, if it will be possible by schema?
by Zom-B » Mon Mar 18, 2013 4:59 am
Here a scene that should show how to use this shared medium thing. You see that the own medium of the "Frosted Glass" is getting ignored (green) since its now using the medium of the "Glass" material (red).
- shared medium.zip
- (19.82 KiB) Downloaded 219 times
Ilay
by Ilay » Mon Mar 18, 2013 5:02 am
Thank you, cool feature.
pzdm
by pzdm » Mon Mar 18, 2013 10:16 pm
oooh, it looks amazing..
btw, works the shadows pass well (inside the C4D?) And the same for mt ID pass, colors were very close together (all green). I have tested the same in Stand alone version, there are not problems...
Many thanks for a reply, Pavel
kklors
by kklors » Mon Mar 25, 2013 2:26 am
Awesome!
Haven't had the opportunity to test it properly yet, but I think all the recent betas got a bug where you would lose resolution and the image get's a weird 1:1 squish once you apply a Layer shader to any Indigo material. I first noticed it with 3.6.6 or 3.6.7 onwards I think.
Users browsing this forum: No registered users and 72 guests
