Search  | Login  | Register
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Offline
Consider this build a test.
32 bit build:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit build:
Let me know if stuff works or not.
Also, I'm interested in performance comparisons with the Windows builds.
 Profile
Offline
Great. Thanks!
Anything not included? (:
_________________
http://simonlarsen.deviantart.com/gallery/
 Profile
Offline
No, I think everything should work
 Profile
Offline
You are a god among...people that are not gods.
Thanks Ono!
 Profile
Offline
Added 32 bit build.
 Profile
Offline
how the two builds compare, anyone had tested them?
_________________
http://nunovasco.pt
 Profile
Offline
unfortunatly not working for me - indigo don't accept values below 1.
eg. it keeps sayin:
Code:
IndigoDriverExcep: SceneLoaderExcep: aperture_radius must be greater than zero (e.g. 0.001)
till i set this value above 1.
and when i set all values within the camera settings in the igi above "1", indigo closes before starting to render.
anyway ... THANKS ono for making a linux version. :wink:
[edit] ... oh, i'm using the 32bit one.
_________________
manitwo.deviantart.com
 Profile
Offline
manitwo, you are my hero :)
Ono see: I´m not doomed :lol:
Does the 64bit version work now, manitwo?
 Profile
Offline
no problem macrob ;)
.... tho no 64bit OS here for testing
_________________
 Profile
Offline
I had the same promlem with the 64bit :cry:
 Profile
Offline
Ok, thanks guys,
I have a suspicion of what the problem may be.
 Profile
Offline
just in case you wanna know, indigo crashes right after:
Code:
Loading Scene '/path_to_my_scene/scene.igs'...
_________________
 Profile
Offline
I just ran the 64bit version on Ubuntu64 hardy (unstable). Loaded+rendered the diffuse_transmitter_test scene perfectly.
It is just a tiny bit slower than the windows version.
linux: 255,000 s/s
windows: 260,000 s/s
EDIT: There's a slight problem with the GUI though, the log window has no scroll bar and not much history (can scroll back a little way with the mousewheel), and the render image fills the entire window, with the log window on top:
 Profile
Offline
I haven't had a chance to test this version, but the .8 era Indigo was 10 - 30% faster in linux than windows, so your results are suprising.
As soon as I get a chance I'll try it out.
 Profile
Offline
strange - rendering something with "indigo" don't work whereas rendering with "indigo_console" works great :? :D
i'm on ubuntu hardy 32bit btw..
_________________
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
