Indigo Renderer 3.2.0
Posted: Thu Nov 03, 2011 3:21 am
Hi all,
We're happy to announce a beta of the next version of Indigo - 3.2.0.
We will be releasing betas in the 3.2.x series until we reach a 3.2 stable release of Indigo Renderer and Indigo RT.
UPDATE: updated mac build. Now works on 10.7.
Major changes:
* Much faster CPU rendering.
* New material editing interface; for more information, see the blog post.
* New local and online material database access from the main UI, and the ability to paint materials directly onto objects.
* New sky model, with much more realistic sunsets and dawn/dusk skies.
* Faster scene load times, especially with large environment maps.
* Aperture diffraction is improved in quality and performance.
* The Indigo installers now have some of the exporter installers (for SketchUp, Cinema 4D, and Blender) bundled. The bundled versions are SkIndigo 3.0.15, Cindigo 3.0.15, and Blendigo 3.0.10 (for Blender 2.4x only, you can find 2.5x exporters here: http://www.indigorenderer.com/forum/viewforum.php?f=8).
There are also lots of other improvements and bug fixes, which you can read about in the full change log below (up to the last release, 3.0.14).
Please let us know if you find any bugs, thanks!
Indigo Renderer:
Windows 32 bit: http://www.indigorenderer.com/dist/beta ... _Setup.exe
Windows 64 bit: http://www.indigorenderer.com/dist/beta ... _Setup.exe
Mac OSX 10.5+: http://www.indigorenderer.com/dist/beta ... r3.2.0.dmg
Indigo RT:
Mac OSX 10.5+: http://www.indigorenderer.com/dist/beta ... T3.2.0.dmg
Major changes:
Indigo Renderer:
Indigo RT:
3.2.0
* Increased ap diffr. filter width from 512 to 1024.
* Fixed bug causing random network connection failures.
* Added local material database action to toolbar.
* Added smooth option to texture editor.
* Enter now selects node for editing (use with up/down arrow).
* Fixed: Mouse wheel up on zoom level combo box zooms out instead of in.
* When 'use floating licence' is checked in options dialog, 'use network manager' is automatically checked and disabled.
* Fixed issue where core tone mapping was not being updated with GUI Changes. (update not being called)
* Networking floating licence info frame is visible again now.
* Fixed crash when model does not have any keyframes. Throws an exception now.
* Fixed slider handle in theme.css.
* Made the network manager put a time-stamp before every log message.
* The network manager now displays a few lines of the latest log messages from the connected slaves.
3.0.22
* fixed scale issues in material preview scene (bump and displacment should now have the correct scale)
* Post-pro aperture diffraction initialisation is now much faster, especially for ssf > 1
* Aperture diffraction images are now cached on disk.
* Fixed some artifacts with aperture diffraction filters.
* Aperture diffraction is now updated when camera params are changed in the GUI.
* GUI no longer blocks when ap diff. checkbox is checked.
* "Emitting object has zero total luminous flux" is no longer an error.
* When render region is invalid, just turning off render region with warning instead of giving error message.
* When user tries to use an Indigo RT licence key with Indigo Full, an error message will be displayed.
* Fixed bug with changing cam tone mapping response path during network rendering.
* Fixed some CUDA memory leaks if a failure occurred.
* margin is now taken into account for trace tay through pixel, fixing slight inaccuracy
* zoom is now in %
3.0.21
* Major updates to Indigo SDK
* Major updates to material editing
* Fixed unnecessary tone mapping updates
* Fixed step_size not being parsed for inhomogeneous SSS
* Optimised emitter building. Much faster in the case with no emission param. Somewhat faster in the case with emission param.
* Fixed crash when subdividing quad with no UVs.
* fixed absorption layer parsing for GlossyTransparent
* fixed displacement persisting when changing material type to blend or null
3.0.20
* Added dock widgets to the "Window" menu, for easy access
* Render threads have lower priority to make the UI more responsive
3.0.19
* Rebuilt new sky data.
* Various material editing GUI changes.
3.0.18
* Greatly improved ray tracing speed on SSE3 CPUs.
* Greatly improved scene building speed.
* Refactored env map sampling. Env map processing is now much faster.
* Fixed ray epsilon issue with scaled objects.
* Fixed lack of absorption in path tracing in some cases.
* Added material ID and foreground alpha rendering modes to UI.
3.0.17
* Added detection of inconsistent media volumes - if found it places the camera inside void/vacuum.
* Fixed occassional camera jump when moving camera in realtime.
* Now reporting the total render time and SPP after render stopped.
3.0.16
* Added <output_path> to .igq format. Should be either absolute or relative to scene_path (currently not supported by UI)
* Fixed a crash that would sometimes occur when long into a rendering
* Added new icons
* Fixed crash when filters were used without a scene loaded
* Added local material database, it holds all materials that have been downloaded from the online database
3.0.15
* Fixed quite a few crash bugs
* Picking an material/object now selects the correct item in the scene graph
* Added material upload, currently only works when editing material files
* Added import material function, that imports a material file (igm, pigm) into the scene (File -> Import Material)
* Added online database browser (Window -> Online Material Database)
* Added material painting
* Added filters to the Scene Graph widget (3 quick filters, advanced filters and a text search box)
* Changed material/media selection dropdowns in material editor to be a textbox instead, from which you can search, also works with drag & drop (from the scene graph)
* Fixed issue with bidir and blend materials with one emitting child.
* Increase spinbox precision on spectrum control gain and texture control.
